Got Brakes???
Old 10-21-2011, 07:28 AM
Obsidian71
Obsidian71's Avatar
Default Got Brakes???
hhhmmmm...whats that grinding noise when I step on my brakes???
Apparently I waited a bit too long to do the front pads on my '00....
oops!
This ones going on the wall of shame
Obsidian71 is offline
Old 10-21-2011, 07:45 AM
02GTman
02GTman's Avatar
My drivers front was worse than that before I changed them.......shame on me!
02GTman is offline
Old 10-21-2011, 07:56 AM
smitty2919
smitty2919's Avatar
How do you guys not notice this??? It took a noise to notice it, not even a loss in braking power first?
There is a thing called general maintenance and check-ups....
smitty2919 is offline
Old 10-21-2011, 08:09 AM
Obsidian71
Obsidian71's Avatar
I regularly check the thickness of my pads when I check tire pressure, rotate tires, and when I'm washing it I always check while I'm cleaning the wheels...my rears started squeaking a bit and I changed them 2 weeks ago. Believe it or not, the fronts didn't make any squeaks or grinds until about 3 days ago, and the outer pads still had PLENTY of meat on them, so I never thought to check the inners till there was a light coating of rust on my wheel after it rained the other day and I knew metal was coming from somewhere cuz aluminum wheels don't rust...took the wheels off and found this! I was quite shocked it didn't make more noise, and I never really noticed a significant drop in braking power... I'm usually more on top of things...
Old 10-21-2011, 09:31 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
Man, that had to be close to showering the highway with sparks.
Which reminds me, it has been a while since I have laid eyeballs on my inside pads too.
fastbackford351 is offline
Old 10-21-2011, 09:51 AM
MythEyeLess
MythEyeLess's Avatar
LOL wow, your rotor must be all warped by now.
MythEyeLess is offline
Old 10-21-2011, 11:05 AM
Obsidian71
Obsidian71's Avatar
hahaha! Rotor! let's just say it's a good thing I had an extra set of factory Ford rotors in my basement that I've been using for mock-up on my '71 project that were in really good shape I got off a parts car a while back...
Old 10-22-2011, 10:23 AM
uberstang1
Chupacabra
uberstang1's Avatar
How could you even let that get that bad, it had to be grinding and making all kidns of noises for a while before it got to that point, time to go for a hearing check.
uberstang1 is offline
Old 10-22-2011, 10:43 AM
mineralpony
mineralpony's Avatar
Those things are worn down so bad haha. What pads did you get?
mineralpony is offline
Old 10-22-2011, 05:07 PM
Obsidian71
Obsidian71's Avatar
Just got regular duralast ceramic pads...don't need anything too fancy.
Quick Reply: Got Brakes???
