first drive... as expected issues...
so aside from the other things that i know need sorted out, my motor is running like absolute garbage and i really have no clue...
its back-firing like a bastard all the time and it just feels like it either loading up with fuel or super lean if i try to feed in any power...
i have an 87 octane tune loaded in (due to the higher compression) and i selected 30# injectors on the tuner...
aside from setting the idle to ~800rpms and raising the limiter to 6600 i really have no ideas wtf could be wrong...
any help would be great guys this OBDII BS is kicking my a$$!!!!
i want my 302 back
i want my 302 back
i want my 302 back
i want my 302 back
- I assume you are running the return type fuel system;
- What MAF are you running?
- What tuning system are you using?
- Did you adjust the tune for the 170° T-stat--not just the fans, the ECT vs AFR tables too?
stock MAF
SCT X3
didnt touch the t stat stuff, the car runs right at 178- 182*, and it does it whether its in open or closed loop, when it first starts for about a minute or so itll be fine then it starts back firing
It's going the run rich as heck with the 170° T-stat and no changes to the various ECT related tables and functions--put a stock 210° (IIRC) thermostat in there and then start to tune the new engine...
im thinking theres something wrong with the injectors maybe?
oh, whats the fuel pressure supposed to be static? ~40psi IIRC?
i need to hook up the wideband and start seeing what it looks like and go from there
"...the car runs right at 178- 182*, and it does it whether its in open or closed loop, when it first starts for about a minute or so itll be fine then it starts back firing"
once the car warms up the avg coolant temp is the 178-182*
if you hold the car at one particular rpm its ok, the minute you alter it up or down itll backfire again
when i drove it when i was driving at one particular speed it was ok but then when i tried to accelerate it would sputter and "load up" it felt like, closed throttle deceleration was fine no issues there
had no power, felt worse than the NPI motor
One thing just occurred to me--Does the tune know you now have a 5.4L engine?
There is a scalar value named Standard Air Charge, used by the PCM to calculate engine load. The current load is one of the key ingredients of the fueling and ignition timing calculations.
If this is still set to the 4.6L value (0.001553) it needs to be changed for the 5.4L engine. The formula is:
2.701e-09 * pi * ((bore/2)^2) * stroke
Where:
2.701e-9 is the lbm/mm³ of air at STP;
pi = 3.14159
bore = the cylinder bore in mm;
stroke = stroke in mm;
So, for the 4.6L engine (90.2 mm bore x 90.0 mm stroke) we get:
2.701e-9 * pi * ((90.2/2)^2) * 90 = 0.001553 lbm/mm³
and for the 5.4 (90.2 mm bore, 105.8 mm stroke) we get:
2.701e-9 * pi * ((90.2/2)^2) * 105.8 = 0.001826 lbm/mm³
Bottom line--the tune needs to be modified to use 0.001826 as the Standard Air Charge value...
Where:
pi = 3.14159
Where:
pi = 3.14159
Where:
pi = 3.14159
no its still a 4.6, just with PI heads and the cams
i never got around to it today, my best friends dad just dies so im taking a break from the car for a week or so, ill let you know when i get back up to work on it, thanks again though
