tuner
Then you want the preadator flash tuner it allows you to turn off rear o2 sensors plus gives you more hp AND its a code scanner for other problems.
The Mustang/Marauder Predator allows the end user to adjust the following parameters:
* Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
* Timing table (+10% / -40%)
* Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
* Fuel table (+40% / -15%)
* Idle (+/- 20%)
* On/Off switch for Traction Control
* Raise Speed Limiter
* Rev Limiter
* Re-Calibrate Speedometer for Gear and Tire Size Changes
* WOT Shift Pressure
* Part throttle shift firmness
* RPM Shift Points
* Torque Modulation (for better shift feel)
* Cooling Fan ON/OFF Temperatures
* Rear Oxygen sensor disable (use for off-road vehicles only)
* Disable EGR (use for off-road vehicles only)
* All of these parameters can be adjusted on the DiabloSport tune and/or the factory tune
* Idle (+/- 20%)
* Rev Limiter
* RPM Shift Points
ernesto-619
Sep 10, 2015 01:32 AM
