Plenum help needed
Old Sep 16, 2005 | 01:29 PM
  #21
Jewjenk's Avatar
Jewjenk
Default RE: Plenum help needed
Gee thanks about the clean engine, I usually wash out the engine bay about once a month.
I do believe that the parts were machined not cast. Only problem was that the acceleration cable was a tight fit on the throttle connection. I will be buying a new throttle cable soon, just in case.
Also had to drill out the screws on the ford unit to free the idle thinggee. Ford used some kind of supper locktight on the phillips heads screws.
Drivability. I have noticed that the revs don't drop as fast between shifts and I guess that as an after effect, there is a smoother shift.
Old Sep 16, 2005 | 09:51 PM
  #22
04BlueGT's Avatar
04BlueGT
I'm curious as to any other mods you have. If you're running the stock exhaust, then upgrading that will really show you what the tb/plenum combo can do.
Nice job. How long did the install take?
Old Sep 17, 2005 | 08:52 AM
  #23
Jewjenk's Avatar
Jewjenk
Just starting on the modes, cold air intake, plus plenum and trottle body. Planning for springs and exaust and possible deleting the rear seat, no adult can sit back there anyway.
Next year will look into lambo doors. That about it for now
As far as install. I am very thorough and carefull, and it was my first time doing it. It took about 3 hours
Old Sep 17, 2005 | 02:42 PM
  #24
Voodoo's Avatar
Voodoo
That thing looks really good.
Old Sep 22, 2005 | 02:43 PM
  #25
04BlueGT's Avatar
04BlueGT
Okay Jewjenk, save money for exhaust upgrades, then gears. (3.73 at least). Of course, you should look at U/D pulleys, timing adjuster, tuner, etc.
If you're doing springs, might as well do the control arms too. New CAs will help you launch.
Lambo doors? Is that the villagers with torches and farm implements I see approaching?
Those doors won't make it faster. Plus, every ricer has them anymore. Don't rice your ride.
Old Sep 22, 2005 | 02:58 PM
  #26
josh4rim's Avatar
josh4rim
ORIGINAL: 04BlueGT
Alright, I say this to everyone...... DO WHAT YOU WANT TO YOUR CAR!!!!!!! If you want to put lambo doors on it then do it. But I have to agree, do the gears you will notice the biggest difference and they are a pretty inexpensive upgrade.
Old Sep 23, 2005 | 06:35 AM
  #27
grimwolf's Avatar
grimwolf
ORIGINAL: 04BlueGT
Anyone have or know of a comparison with C&L, Dragon, or Accufab? I was leaning towards Accufab, but the price for this one is much better than any of the others. Guess there is only one way to find out, huh?
im a little late on this but over on modular depot they did some testing...they said the acufab setup plenum and throttlebody got more hp and torq then the c&l and dragon...just going by what they said...personaly i have a 75mm acufab throttlebody and plenum with a c&l mafs kit and intake...
here is the review
http://www.modulardepot.com/?show=articlesdet&aid=30
Old Sep 23, 2005 | 07:05 AM
  #28
03GTType's Avatar
03GTType
nice find grimwolf, been looking for something with different brands
Old Sep 23, 2005 | 10:31 AM
  #29
Jewjenk's Avatar
Jewjenk
Ok, ok, I won't do the Lambo doors, actually it was only a thought. My next mod though will be a front strut brace, I did order one with the other stuff but they sent a 1993 brace instead of a 2003, it ws sent back for a replacement.
The next step will probably be subframe connectors and then springs with an exaust following.
Oh I did post a seating problem, that was corrected by the dealer, under warranty.
Old Sep 23, 2005 | 02:32 PM
  #30
04BlueGT's Avatar
04BlueGT
ORIGINAL: grimwolf
ORIGINAL: 04BlueGT
here is the review
I've seen that one before, but I have not found one for the tb/plenum in question. I'm pretty sure this company is new to Mustang parts.
