Making my GT into an amature racer
Well a bit ago i decided id build a stroker setup after doing extensive research i turned away from that and decided to save and build a race car for the track days at VIR i live only an hour away and it would give me the much needed relaxation and personal time i need just racing it in my free time. So i have come for the opinions of my fellow mustang lovers for what i should do with the car my plan below is what id like to do with the car and have not really decided on any particular brand as of yet so help me out guys with the setup for my track monster!
I decided to buy a used SVT engine off ebay and build that once dropped in ill sell the GT engine and gain a good bit of money back
Break up grade to 4 piston calps and high performance breaks
Coil overs
Sub frame connectors
Roll cage
Drilled and slotted rotors
Back seat delete (i will leave dash and passenger seat i will be driving it to the track and driving it around some and would like the interior to remain good looking)
Stand alone fuel management system
slightly higher than standard SVT injectors
Fuel pump upgrade
Stage 3 clutch w/ aluminum flywheel
drive shaft upgrade w/ safety loop
wider rear tires w/ performance track tires
The exhaust will be changed to that of a Cobra R (sorry i love the look im aware its somewhat restrictive)
Cobra R front with splitter
engine mount upgrades
T-5 Trans
From what i have been told if i can plant about 500 hp to the ground with figures just above that in TQ it will be plenty at VIR to keep up with 90% of people out there after that its all the driver
Im plenty open to suggestions cant wait to here what you guys have to say
Coil overs
Roll cage
Fuel pump upgrade
T-5 Trans
Its on 03-04 SVT cobra engine
The trans is a T-56 not 5 excuse me
I have about 18000 atm to spend but will be upgrading bits at a time until its where i want
and 11s or 9s? VIR is not a drag track its a circuit
video of VIR
http://www.youtube.com/watch?v=9JqhHi3DlFw
video of VIR
wow, nice spending limit! like i said above, just go racing like you are and then upgrade as you need to. but if that money is burning a hole in your pocket, look at the mm grip box. that engine setup you have along with the mm setup with a set of sticky tires will be a nice setup. gears would be a step forward and a set of front cobra brakes. dont forget seats and harnesses. a car is only as fast as its driver and they will help you stay planted as you corner hard
