2004 gt o2 sensor stuck on lean
2004 gt 4.6 this is what i have
75mm acufab throttlebody and plenum with a 85mm c&l mafs and intake, steeda non piggy back underdrive pullies, pro 50 shifter and thats all i have installed at this time. gears and headers are not going on until i have my cel problem fixed
everything ran fine for like a month...then i put my basani off road xpipe on, and 10 minutes down the road o2 sensor 2 in bank 2. thats down stream on driver side trips the check engine light...so i plug my diablo tuner in and read the code and thats what it says..ok so i reset it.so i installed the diablo tune to see if that would maybe bump things up a bit to correct it...no go so i returned the tune to the stock one (gas prices suck in ny) .even pulled the battery terminal for ten minutes once to see if i had to do a diffrent type of reset...
still comes on..
any ideas? should i scrap the mass air meter? could that be the problem? or should i need to get a wide band o2 sensor? im car stupid but i did a search on this site before i posted this and all i found was stuff for 5.0 mustangs.
any help or input would be greatly appreciated.
still comes on..
RE: 2004 gt o2 sensor stuck on lean
Well with an O/R exhaust you don't have catyletic converters right? If that's he case you will need to get some MIL eliminators or a special chip that sets the code to not ready.
Use your diablo to shut off the rear o2 sensors!!!! that will take car of your problem, you do not need the MIL eliminators as your predator tuner can turn them off!
in reply to sk8erdudex...i already did the mil i forgot to mention that my bad
and in reply to driver thanks dude umm question...where do you go in the diablo to turn them off cuse im not sure where to look.
thanks ill tinker around with it on my day off right now i gotta run to work but ill look to see if i can find the option..and check back here later or tomorrow
I'm reading a lot about people having problems with MIL Eliminators failing nearly instantly.
Seems to be frequent with the Steeda's. Like everyone else said, you can shut off the rear O2 sensors via your handheld.
BennyBlown2v
03-23-2008 02:50 PM
MustangMandy04
01-06-2007 11:06 PM
