How much HP??
How much HP??
1998 Black GT Manual : PI H/C/I pro 5.0 short throw, stage 2 clutch, BBK cold air intake, steeda lower control arms, steeda full length subframe connectors, Caster & camber plates, Eibach Pro-street adjustable coil overs, UPR off road x pipe with flowmaster super 44's, 4:10's,
with my mods how much hp and torque
also the cams are comp stage 1 cams
and the heads and intake are from a 03 GT that are polished.
The exact numbers will vary depending upon the dyno used, but... probably around 275rwhp/296lb-ft with the 93oct tune.
Be sure to get both the SAE corrected numbers and the raw uncorrected numbers from the dyno pull.
Let us know how it goes.
BTW, where are you having it tuned and dyno'd???
