pulleys
Old Sep 16, 2005 | 09:49 PM
lovemyponies's Avatar
lovemyponies
Default pulleys
hey all. i have a 2004 mustang gt. im wanting to get pulleys . can anyone tell me which ones i should get and should i expect any problems after replacing.
Old Sep 16, 2005 | 09:59 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: pulleys
Steeda pulleys.... Whatever you do, dont get the piggyback style if you go with something other than steeda. No you shouldnt have any problems either.
Old Sep 16, 2005 | 10:20 PM
blueangelfightr's Avatar
blueangelfightr
Default RE: pulleys
Steeda. There should be no problems.
Old Sep 16, 2005 | 10:23 PM
lovemyponies
Default RE: pulleys
are the bbk ud pulleys piggyback style and what does that mean?
Old Sep 16, 2005 | 10:28 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: pulleys
Yes BBK are piggyback thats why they are alot cheaper than steedas. Piggyback= pure s---. They are known to do severe damage to the crank. Get the steedas and be done.
Old Sep 16, 2005 | 10:31 PM
blueangelfightr
Default RE: pulleys
Piggy back means it goes over your existing ones.
Old Sep 16, 2005 | 11:15 PM
4600cc's Avatar
4600cc
I ♥ Acer
Default RE: pulleys
Why would piggyback crank pulley do severe damage to the crank? How?
Old Sep 17, 2005 | 12:00 AM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: pulleys
They can do severe damage if they are not balanced properly. I have a friend with a 96 GT with piggyback pulleys and they tore up his crank pretty bad. Had no idea that they were off balance. Everything looked and sounded fine while car was running. Non piggyback are a direct bolt on after factory pulleys are removed. Piggyback bolt onto the factory crank which is not a real good idea.
Old Sep 17, 2005 | 12:11 AM
josh_0351's Avatar
josh_0351
Default RE: pulleys
ORIGINAL: lovemyponies
Yes, and it means that they attach to you existing crank pulley – I believe there is a sticky on this topic FYI. Go with the Steeda’s!
Old Sep 17, 2005 | 12:23 AM
4600cc's Avatar
4600cc
I ♥ Acer
Default RE: pulleys
ORIGINAL: sprostang
I was going to go with biggyback because I want to keep stock crank balancer. Exactly how do balance them properly, does installation instruction tell you how to install properly those pulleys?
