GT DYNO Results
Old Sep 17, 2005 | 07:32 PM
ZW99GT's Avatar
ZW99GT
Default GT DYNO Results
Today in knoxville,tn LMS motorsports had dyno day. I thought nothing of it and got up and went. Little did i know these dudes were for real! They tune Ferrari's and Porsche's ( there was a Ferrari 355 challenger sitting right beside me!). After about 3 million corvettes and camaros, It was fords turn. A guy in a foxbody put down 244hp which wasnt bad at all. 2 04 wipple cobras took the hotseat and laid down 580hp 535TQ. The other one had too much timing and f'd up. Finally it was my turn, and i really surprised myself. Check it out. Keep in mind this was a Mustang Dyno.
[IMG]local://upfiles/10124/618CD80BACA24C298BEDCF16EBE1B032.jpg[/IMG]
Old Sep 17, 2005 | 08:07 PM
red2k1gt's Avatar
red2k1gt
Default RE: GT DYNO Results
that seems low to me...I dynoed 232/273 on a mustang dynamometer and the only mods i have are in my sig
Old Sep 17, 2005 | 08:13 PM
blueangelfightr's Avatar
blueangelfightr
Trade those shorties with long tubes and get some heads/cams. Then you'll really be putting the numbers down. But not too bad for the mods you have. Was it a hot day?
Old Sep 17, 2005 | 08:15 PM
red2k1gt's Avatar
red2k1gt
heat shouldnt matter too much since the dynamometer takes heat/humidity into consideration when it puts out numbers.
Old Sep 17, 2005 | 08:27 PM
blueangelfightr
Oh yea, I forgot that. Those dynos take alot into comsideration.
Old Sep 17, 2005 | 10:42 PM
neogenic83's Avatar
neogenic83
each dyno you go to will read alittle diffrent. tire pressure can throw them off also he has gears which throw the 1-1 ratio off so that will show alittle lower hp numbers
Old Sep 17, 2005 | 11:19 PM
red2k1gt's Avatar
red2k1gt
Im still baffled as to why gears give you a lower HP read out? Can anyone explain it?
Old Sep 17, 2005 | 11:41 PM
Dave2000GT's Avatar
Dave2000GT
ORIGINAL: red2k1gt
More loss through extra gear-tooth contact.
Old Sep 18, 2005 | 12:25 AM
ZW99GT's Avatar
ZW99GT
This guy who ran the shop has a Phd in engineering. He's been working on Ferrari's for years and has owned a dynojet and a mustang dyno. He says 7-8% difference depending on the car. If u take 7% of 238.6 thats 19.xxx. 238+19=257. Which is right where i need to be. Dont see what ur arguement is. your car should not have gotten those high of #'s not the other way around.
Old Sep 18, 2005 | 04:12 AM
racer02GTstang's Avatar
racer02GTstang
nice seeing you at the dyno earlier.... sorry i couldnt stick around, i had to go get to work.... maybe some other time we can go to another dyno day or somethin.
