98 GT power window problems
Old 05-30-2012, 04:22 PM
1998Slow 'Stang
1998Slow 'Stang's Avatar
Default 98 GT power window problems
I'm having problems with the drivers side power window only. Both the drivers and passenger side switches operate the passenger side window normally.
However, the driver side window will only go down with the automatic down feature where you just tap the button....although if you hold the switch it seems to act like it blew the fuse (only momentarily though) and the radio resets then it will go back to the aforementioned problem.
If anyone has any ideas they would be extremely helpful!
1998Slow 'Stang is offline
Old 05-30-2012, 04:58 PM
1998Slow 'Stang
Edit: the drivers side window will only do the auto down with the key on accessory. With the key on it will not go down. The voltage gauge drops substantially when trying to put it down.
Old 05-30-2012, 11:43 PM
russellthelovemuscle
russellthelovemuscle's Avatar
one way to figure that out, multimeter and wiring digram
russellthelovemuscle is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
JonnyBlazeGT
11-03-2015 01:10 AM
movielover40
08-27-2015 10:13 PM
HorsePower99
08-26-2015 11:29 PM
Quick Reply: 98 GT power window problems
