Injector sizes
With my current modifications, the soon to be installed CNC Stage 2 heads, P-51, & cams...Comp says that I will need to upgrade to 24lb's. However, someone I spoke w/yesterday who has a blown GT says that I will need 30lb's.
Here's a his logic: He says that the 24's will work just fine, but 'if' I do anything else to my car to add more power, at this point, I will need larger injectors anyway, so I should go ahead & get them now to save some money.
Here's mine: I don't plan on adding boost or juice anyway (I told Denns from Comp who incidentally no longer works there anymore...found that out yesterday...that I wanted to stay N/A when I was ordering my grind, so all that I could possibly do would be to stroke it (which I not sure will need bigger injectors anyway). Truthfully, I'd like to have my car completed less a nice set of Cobra rims to finish it off before Christmas. I really have no plans of adding anything at all to it after this h/c/i swap however, I've been known to change my mind.
Feedback please...
btw...off subject...how does that lope sound from Comp as compared to VT or any others? The cam I have is closest...hell pretty identical to the xe270 Hot Street, so I am just curious if it will sound as menacing as I am imagining?!
Feedback please...
I am also looking at almost the same set up as that. I am looking at Fox Lakes stage 2 heads VT stage 2 cams, and will be getting the P-51 intake here in a couple of weeks. When I install the H/C I will also put on headers. I am going to get #30 injectors for this set up. Code3gt is also running #30 injectors. I would suggest that you get the #30 ones over the #24 one just because you do not want to have to change them out more than once. JMO
I think #24s will work fine, but #30s will not hurt anything. I think you'll need a new or recalibrated MAF sensor for the new injectors.
Go big.
MOTOBLUE has an 85mm housing and so does C&L. The N/A Cobras were cal'd for #30 or #36. They are 90 or 95mm.
jdaniel, does he need to look into a bigger pump or maybe fuel rails? (okay, not the rails, but they look nice)
Go big.
I decided to go w/30's. As far as the MAF change...done that a long time ago[8D]. Also, the P-51 will provide all the equipment I need as far as fuel lines are concerned and what not.
ORIGINAL: 04BlueGT
Is your MAF calibrated to #30 injectors? I think you have to recalibrate it to match. jdaniel or code3gt would know.
