Speedometer LED lighting Kit
Old Jun 26, 2012 | 11:07 PM
stevednmc's Avatar
stevednmc
Originally Posted by pfc_gomez
I thought it would be a pain in the a** do replace the bulbs but this makes it look simple. I think I will give it a try.. 1 question though my dash looks green so I imagine after the LEDs it will still look green? Any way to change it? but I do have a green stang though so should I leave it green? But Blue looks super nice!
If its a 2002 then no matter what it will look green unless you remove the film from behind the gauges. This will rewuire you to go a little further into the gauge cluster than just changing the bulbs as indicated in that write up. Not a big deal, just be prepared for it.
FYI these are the bulbs that fit 2002 -04 instrument clusters:http://www.superbrightleds.com/vehic...mustang/20/758 (Instument-General 37 base.)
The WLEDx5 are too big. At least in my experience. Ford changed them mid year 01.
Old Jun 27, 2012 | 12:57 AM
barqsdrinker's Avatar
barqsdrinker
If they changed mid-year, how can I tell which "version" I've got with my 2001??
Old Jun 27, 2012 | 09:52 AM
1998Slow 'Stang's Avatar
1998Slow 'Stang
Take the cluster apart and look through the back side of the gauge.
Old Jun 27, 2012 | 04:22 PM
stevednmc's Avatar
stevednmc
Or more simply look at your water pump pulley. IF its concave its newer style (short shaft) You can look at the build date and see if it was built in late 2000-early 01 as well.
Old Jun 27, 2012 | 06:15 PM
1998Slow 'Stang
Do it this way, much much simpler.
Old Oct 3, 2012 | 12:47 PM
69MustangCoupe393cid's Avatar
Which wled5x bulbs do you need for this? I see a few options.
Old Oct 3, 2012 | 12:53 PM
Shampue's Avatar
Shampue
Wouldn't it just be cheaper to buy the overlay from American Muscle? Then you get white faced gauges plus an LED glow.
Old Oct 3, 2012 | 10:09 PM
I personally think those are very cheap looking. I'm not really a fan to be honest.
Old Oct 4, 2012 | 07:48 AM
Shampue's Avatar
Shampue
I dunno, everyone who sees mine thinks its factory
Old Oct 5, 2012 | 02:01 AM
Dubwhat's Avatar
Dubwhat
Is that not because the cobra cluster has white faced gauges?
