Milk Shake
Old Jul 27, 2012 | 05:52 PM
Ketch's Avatar
Ketch
Default Milk Shake
Hi guys i have a 4.6 gt 1996 and i had a overheating problem (oil in the water lines) i changed the head gaskets and 2 months later i have a milk shake problem again but this time it is also in the oil pan and cooling system. Any suggestions of what it could be --please dont say head gasket please
thanks
Old Jul 27, 2012 | 05:55 PM
JC316's Avatar
JC316
Could be the oil filter adapter plate gasket. Oil and water flow through there and if it breaks, they can mix.
Old Jul 27, 2012 | 06:18 PM
Ketch's Avatar
Ketch
Thanks JC316
i did replace the gasket there as well. The motor runs so smooth i hate to do a head gasket all over again
Old Jul 27, 2012 | 06:46 PM
JC316's Avatar
JC316
Hmm, that isn't good. I only know of three ways for water to mix with the oil on a modular and that is the oil filter plate, the head gasket, or a cracked block.
Old Jul 27, 2012 | 08:47 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
^+1, that's all there is--but one.
If you have a slushbox, transmission oil could get into the coolant through the tranny cooler pipe in the radiator--but it would not smell anything like that nasty odor motor oil and coolant make...
Old Jul 27, 2012 | 09:35 PM
BraMas's Avatar
BraMas
You could have a warped head and that would make it so coolant could leak past your new gaskets
Old Jul 27, 2012 | 10:18 PM
1998Slow 'Stang's Avatar
1998Slow 'Stang
If it's unclear, by "slushbox" Cliffyk is reffering to an Automatic Transmission
This one got me too
Old Jul 28, 2012 | 03:09 PM
Ketch's Avatar
Ketch
thanks for the replys guess ill be doing the head gasket again
is there anything i should look for after the head is removed?
again thanks for the help
Old Jul 28, 2012 | 04:59 PM
uberstang1's Avatar
uberstang1
Chupacabra
Take the head to a machine shop to ensure its not warped
Old Jul 28, 2012 | 05:21 PM
Tom V's Avatar
Tom V
You did have the heads milled the first time?
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Nov 18, 2015 01:34 PM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
mdj89
Aug 31, 2015 07:27 AM
