Vibration after Clutch Install
I just had a new throughout bearing clutch and fly wheel installed.
At idle the car has a slight vibration. If I rev the engine the vibration gets worse. could the flywheel be out of balance?
What else could be the issue?
Or, less likely, that the pilot bearing is shot (was that replaced?).
I'm pretty sure the bolt holes on the flywheel are spaced in a manner that it only goes on one way. But I'm with cliffy sounds like its not torqued correctly or the pilot bearing is smoked.
The holes are evenly spaced about the bolts circle there is no "right or wrong" mounting, just the one there is...
Here's where i am at to date. Pulled the new clutch and pplate out and replaced it with ford oem. This made a huge difference in minimizing the harshness of the vibration but it is still there. In neutral at 1000 rpm it can be felt the most. between 1kand2k it goes away but can be felt again at cruising speed slightly. After reading post after post i am at a loss. My mechanic wants to try replacing the harmonic ballancer next but i don't think that is going to make a diffenrence. Pilot bearing is new and the fw torque checked. Any suggestions would be greatly appreciated. I don't want to ruin the engine.
It could be the balancer, but it could be a motor or trans mount as well, or a bunch of other stuff for that matter. My next question when you removed the driveshaft did u scribe a mark on the pinion flange on the rear end, and reinstall the driveshaft in the same position?
The car vibrates even sitting in neutral without anything engaged. That should rule out any issue with the driveshaft. Transmount is fine not sure about motor mounts. Mechanic suggested replacing the damper. The more i search for an answer the more i am finding out that i could spend thousands replacing parts trying to track this down. I may just have to live with it for now.
Check both of the mounts. The fact you just had a clutch replaced probably put extra stress on one of them and it finally gave up the ghost. If the flywheel check comes up without any concerns and the shaft was appropriatly marked and resinstalled It wouldn't hurt to replace the mounts. They are cheap enough. Do not install Polyurethane ones, they just increase NVH on a DD.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
