Strut identifier question
Old Sep 6, 2012 | 09:51 PM
stangj2002's Avatar
stangj2002
Default Strut identifier question
So I'm checking my struts and wondering if someone can help me identify if they are stock or aftermarket. I see no branding other than the following:
747019
Q11062
They are black
Made in Mexico
I think I know the answer to my question, just want to be certain. Thanks
Old Jun 21, 2019 | 10:00 AM
Gomedic's Avatar
Gomedic
Default Age?
Did you find out if they were stock??
Old Jun 21, 2019 | 03:28 PM
GT Nate's Avatar
GT Nate
Go to Rockauto.com and they sell preassembled struts,, all you have to do is:
1: Undo the top strut bolts under the hood
2: Undo two big bolts holding the strut to the lower control arm
3: undo the sway bar end links
4: remove strut
5: do reverse to put in new pre assembled struts.
10 minutes each side no alignment necessary!
easy as pie amigo.
Old Jun 25, 2019 | 03:38 PM
Z28KLR's Avatar
Z28KLR
4: remove strut
easy as pie amigo.
Might also wanna set up your floor jack under the A-arm with just a slight amount of preload on the suspension before loosening anything up.
Phil1098
Jul 24, 2014 09:40 AM
hpwrestler220
May 8, 2011 07:07 PM
Benr7132
Feb 17, 2008 10:20 PM
Saleen150
Jul 29, 2006 05:20 AM
nualln
Jul 13, 2005 11:12 AM
