Cobra cyl heads on a GT?
Old 09-11-2012, 06:52 PM
FLYBOY_GT
FLYBOY_GT's Avatar
Default Cobra cyl heads on a GT?
Hi everyone. just had started pondering this topic. I have found a set of cobra heads including cams all put together for really cheap and im wondering if it is possible to put the cobra heads onto a regular 99 gt? i understand i have to get intake and exhaust manifolds and lots of others but I still want to know if it can be done or if anyone has done it?
thanks
FB
FLYBOY_GT is offline
Old 09-11-2012, 07:03 PM
motorman524
MF Informant
motorman524's Avatar
Definitely doable, I've seen it done on another forum before. It takes a lot of parts collecting though. It would make more sense to me to buy an assembled engine to drop in.
motorman524 is offline
Old 09-11-2012, 07:13 PM
jrp1588
jrp1588's Avatar
Seems like I've read the GT pistons matched with the cobra heads make for low compression. Could have made that up though
jrp1588 is offline
Old 09-11-2012, 09:08 PM
Convex
Convex's Avatar
I think it will (not 100% sure) work but your timing/fuel/air would need to be adjusted for the 4v heads within the computer level of the car.. same issue with dropping a 4v engine in as you would need everything right down to the computer to make it work.
Convex is offline
Old 09-11-2012, 09:20 PM
school boy
school boy's Avatar
you can, BUT the conpression will be at 8.5 to 1. if the heads are assembled, then you will need:
exhaust manifolds
complete intake manifold and throttle body
cold air intake
valve covers
timing chain covers
coolent hoses/thermostate housing
coolent crossover
cop's
new head gaskets
altinater
your cop harness will need to be modded
the gt tune will be fine for a while be get it tuned
school boy is offline
Old 09-12-2012, 04:48 PM
reno27
reno27's Avatar
alot of work and money thought about aftermarket 2v heads?
reno27 is offline
Old 09-12-2012, 06:50 PM
mvr
mvr's Avatar
ever thought of going to the junkyard and pulling a teskid block and building a forged motor on the side. might take a while longer depending on your money constraints but it would be well worth it and you can still drive the car for now.
mvr is offline
Old 09-12-2012, 09:38 PM
school boy
school boy's Avatar
new aftermarket heads would still be more than a 4v swap. if it was me, i would either do a spare forged engine build like mvr said, a mark viii 4v engine swap or run a intercooled vortech
Old 09-13-2012, 09:14 PM
rocket22
rocket22's Avatar
Default ugh...a much easier way
sell yours and buy a cobra. Or do an engine swap. Way too much effort and possible issues.
rocket22 is offline
Old 09-14-2012, 01:39 AM
scott4.6
scott4.6's Avatar
I would just do trickflow 195 r head and call it a day. It would be ALOT easier and the heads , from what i have read will out flow any stock 4 valve
scott4.6 is offline
Quick Reply: Cobra cyl heads on a GT?
