lot of white smoke from exhaust
Old 11-24-2012, 09:51 AM
NewEdgeStang00
NewEdgeStang00's Avatar
Default lot of white smoke from exhaust
I just needed to get some opinion from you guys on if I should worry about the large amount of white smoke spewing from the exhaust. Its started happening ever since I got an o/r H pipe. (Already have a super 40 series flow master american thunder cat back.)
I been told smoke and smell would be imminent, but just noticed when I passed a store window while driving that there's also a lot of smoke coming out while driving too, and worse when idle/parked.
Is this a serious issue or something just the o/r midpipe will do to me?
NewEdgeStang00 is offline
Old 11-24-2012, 10:55 AM
uberstang1
Chupacabra
uberstang1's Avatar
Does it smell like oil? did u damaged or install the o2 sensors incorrectly
uberstang1 is offline
Old 11-24-2012, 04:31 PM
NewEdgeStang00
I put my hand to the smoke and it felt like steam, smelled a little like gas
Old 11-24-2012, 04:42 PM
1slow67
ROTM Moderator
1slow67's Avatar
1slow67 is offline
Old 11-24-2012, 05:27 PM
T.Richardson
T.Richardson's Avatar
I think thats normal. But excessive smoke is a little concerning.
T.Richardson is offline
Old 11-24-2012, 06:19 PM
NewEdgeStang00
Yeah I wouldn't be worried about it, and haven't been worried until I noticed it looks like a fog machine behind my car.
Old 11-24-2012, 07:50 PM
rygi23
rygi23's Avatar
It's just the no cats. Not sure what changes you've done to the car but running rich will accentuate this some. As long as it smells like gas and not oil I wouldn't worry to much without any performance symptoms.
rygi23 is offline
Old 11-25-2012, 06:48 AM
petrock
petrock's Avatar
The human nose is not a reliable measuring device in my opinion.
Three possibilities for the smoke. Coolant leak into one or more the cylinders, oil leak into one or more cylinders, or unburned fuel coming out the tail pipe from a stuck open injector or similar issue. All three are things to be concerned with, but are easily testable.
I'd hook up a radiator pressure tester (available for rent at most auto parts stores) and make sure you don't have a coolant leak. If that checks out, then top off the oil and drive it around for a week or so to see if the oil level drops. I'd also hook up a scan tool that does live data (available at most auto parts stores) and check the short & long term fuel trim numbers. If the sum of the long & short term fuel trim numbers is in the single digits, then its normal. If the sum is positive then the computer thinks the motor is running lean and is adding fuel to the mix to try to correct it. If the sum is negative, then the computer thinks the motor is running rich and is removing fuel from the mix to correct it. If the smoke is from unburned gas, the sum will be negative in the double digits.
The only time, in my opinion, smoke coming out of the tail pipe is 'normal' is when the outside temp & the motor are both cold. Otherwise, its not normal and is an indication of a problem. If you can see it in the reflection of a window, as you described, it's excessive.
Good luck...
petrock is offline
Old 11-25-2012, 08:05 AM
uberstang1
Chupacabra
uberstang1's Avatar
sounds like normal condensation to me, if it was burning coolant or oil u would smell it.
Old 11-25-2012, 10:36 PM
petrock
petrock's Avatar
If it were normal condensation it would be burned off by the time the motor was warm. From the OP's initial post, the smoke persists while driving which to me sounds like the motor is warm), so its not just condensation.
petrock is offline
Quick Reply: lot of white smoke from exhaust
