dyno testing wrong?
Old Oct 4, 2005 | 10:46 PM
lovemyponies's Avatar
lovemyponies
Default dyno testing wrong?
i had steeda udp installed today. got in my car and found a sheet of paper with a chart.
im thinking car was dyno tested or something., dont know much about the dyno stuff.
anyway i have a 2004 mustang gt, ive got the pulleys plus mac cai and flowmaster delta
force 2 catbacks.
here's the numbers on the sheet
max power 194.5@4750 rpm
max torque 230.4@3750 rpm
am i reading this wrong i thought a stock 2004 gt had 260 h.p.
Old Oct 4, 2005 | 10:55 PM
blueangelfightr's Avatar
blueangelfightr
Default RE: dyno testing wrong?
260 at the flywheel. Was this a mustang dyno? If so then the numbers aren't too far off. But still a tad low for a modified car.
Old Oct 4, 2005 | 11:23 PM
pete1665's Avatar
pete1665
you really loose 60 hp throught the drivetrain? that seems like a lot...
Old Oct 4, 2005 | 11:41 PM
blueangelfightr
It depends. On a mustang dyno maybe. On a dynojet, no way.
Old Oct 5, 2005 | 01:47 AM
Dave2000GT's Avatar
Dave2000GT
Those number are way too low a stock mustang shouldn't dyno less that 215 on anything even a mustang dyno. My guess is that it was from a part throttle pull.. or they were testing for something else.. like spark or a/f ratio etc.. and the power numbers just happened to show up as well even though they weren't what was being dynoed.
Old Oct 5, 2005 | 02:37 AM
DuckyGt's Avatar
DuckyGt
ORIGINAL: pete1665
you lose about 15% through the drivetrain in a stick and about 20% with a auto.
Old Oct 5, 2005 | 12:12 PM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: lovemyponies
force 2 catbacks.
I doubt they would dyno your car and not charge you for it. It is probably just someone elses dyno that they took in the car with em to move it around the shop, and then forgot to grab it when they got out.
Old Oct 5, 2005 | 12:39 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
You guys are also forgetting that simple things such as how the car is placed on the rollers can affect the numbers on a dyno. Latley I have seen threads on here where people have had their cars on dynos and they were run in third gear and other such dumb mistakes. Personally I am at the point where unless I know the dyno and the guy running it or it is a super reputable shop I just don't put much stock in the numbers.
Old Oct 5, 2005 | 02:33 PM
Dan04COBRA's Avatar
Dan04COBRA
Those numbers are WAY off.
Old Oct 5, 2005 | 02:52 PM
Tim37's Avatar
Tim37
you alson have a mustang dyno and a dyno jet. a mustang dyno gives you lower (more true to life) numbers. don't put too much stock in to a dyno in my oppinion they are great for tuning. there are some many things that can change those numbers you can take a car put it on a dyno run it let it cool down to the same starting temp and the numbers will be different.
