bigger fuel injectors?
Your '04 has the pink (lavender) 21 lb/h injectors, good for 320 fwHP (flywheel HP); 270 at the wheels. Your build, with a decent tune (you did not mention a tune/tuner), will certainly meet and likely beat that limit. 24 lb/h injectors would be "dead on" for your setup, or even 30 lb/h units.
You will of course need a retune when the injectors are upgraded.
The stock MAF can meter up to 2600 lb/h air flow before "pegging", that is enough air for 385 fwHP, 325 at the wheels and should be fine for what your are doing.
However, fuel injector duty cycle percentage was not even brought up 1 time during my appointment. He only asked what injectors I had and that was it, past that, the only remark made was that the fuel system was fine. The fuel pump was at 75% for the n/a tune and 82% for the 48 jet nitrous tune, I do remember that.
I will answer this by starting another thread, after I get back from a little league game. As for those that have asked about focus pumps, you can usually find them listed for sale on corral.net. That is where I picked mine up for $70 shipped.
I was hoping Kurgan had the logs from my pulls, but they don't keep them. So, I thought I would just plug up my actron that has 121 pids to choose from and scrolled right down to fuel pressure. Time for a test drive! I mounted it up so it was just like looking at a gauge and made 3 pulls in fourth from 3500 to 6000. And guess what..... 39.8 to 40.7 psi!
I knew Kurgan didn't mention fuel pressure for a reason, it's because he left it alone!
Ok, some of you made me curious!
