jmod help
Old Jun 4, 2013 | 09:53 AM
harbre32's Avatar
harbre32
Default jmod help
OK I have a 2000 ft auto. I did the jmod and all went well. No when the car shifts into overdrive it seems to take a while. It almost feels like it slips a little then engages. Its no clean and smooth like before. Is this normal? Did I do something wrong?
Old Jun 5, 2013 | 05:38 PM
Vertigo_GT's Avatar
Vertigo_GT
Bump . I don't even know what the hell a J mod is.
Old Jun 6, 2013 | 05:14 PM
Subbz's Avatar
Subbz
Jmod is a somewhat simple mod you can do to the valve body by drilling holes in it that from what I understand pretty much changes the way it shifts much like an automatic shift kit or a performance valve body. I haven't done this to my car so I wouldn't know if it was normal, but try dropping down your transmission pan and check to see if there aren't any chunks of metal in there just to be on the safe side.
Old Jun 6, 2013 | 05:22 PM
Vertigo_GT's Avatar
Vertigo_GT
Thanks Subbs.
Old Jun 6, 2013 | 05:53 PM
Subbz's Avatar
Subbz
You're welcome! And the Jmod is only specific to automatic transmissions. It's supposed to help the car shift as fast as a manual transmission.
Old Jun 6, 2013 | 08:16 PM
harbre32's Avatar
harbre32
No metal
Old Jun 7, 2013 | 06:23 AM
Stevo86's Avatar
Stevo86
You drilled holes? In your valve body? And expected not to have issues? Hahahahaha Brilliant. Next time get a tuner.
Old Jun 7, 2013 | 07:56 AM
Sonic Mustang's Avatar
Sonic Mustang
Banned
I'm still working on 2000 ft.
Old Jun 7, 2013 | 11:06 AM
Subbz's Avatar
Subbz
Originally Posted by harbre32
No metal
Does your O/D off light start flashing even when you don't turn it off manually?
@Stevo it's a known cheap mod to get the same effect as buying a shift kit or a performance valvebody if done correctly. It's fairly simple to do if you follow the instructions correct though I'd never modify the valvebody myself. I'd rather spend the $300 for the valvebody than having to replace the entire transmission.
Old Jun 7, 2013 | 08:23 PM
T.Richardson's Avatar
T.Richardson
It's actually a popular modification for auto trans.
