Mark VIII swap problems
I'm doing the same swap, I'm just not as far along as you are. Some people say you can get a pigtail from autozone some say you have to go to ford. Here are Two link to different swap guides. Let me know if this helps or what you end up doing.
http://www.mustangmodders.com/forum/...Mark-VIII-Swap
http://www.moddedmustangs.com/forums...ap-thread.html
I figured it out Shannon. You have to get the plug for the mark 8 alternator. once you get the mark 8 plug, connect the yellow and white wires and the green and red wires together. Just tape up the extra black wire. Its an extra wire you don't need for the mark 8 alternator. The connection is inside the alternator already. I talked to pa performance and they confirmed it. Let me know if it works for you. Does your car crank? My battery light went away once I did that. I just can't remember how to hook up my battery harness. I must have a bad harness because the starter won't kick in and I know its a good starter because I had both tested and I tested them with a spare battery.
so whats the exact wiring combo? kind of confused the way you put it. As of my car cranking I was able to drive it because I had a fresh battery so I was driving just on the battery the only thing was the alternator
charging issue
When I was doing the swap almost everything I read said to get a plug from a mark VIII. So I did the local pull-a-part had one I have been getting misc parts from. Most of the guides said to swap the two wires. I did, when I first started it up the battery light was on. I swapped them back to the way they were color on color. The light went off it is charging. I did find a plug from a 98 mark Viii. Here are a couple of pictures. hope they help.
shannon, follow what bgim said. his description is much clearer. get the mark 8 alternator plug and connect the the two wires color for color. the wires are probably dirty but there should be a yellow and white one and a light green and red wire. connect them to the same color wires coming off your main harness and you will be fine. my car isnt here since i moved to houston or id go out and send you pictures. but bgrim gave an excellent description. i hope you got it to charge. let us know your progress.
