timing adjuster?
I just got my predator tuner and I know the timing can be adjusted wit it, but it is on at wot. Should i buy a timing adjuster from steeda and if yes how do you actually adjust the timing with the thing?
Thats what I would do. Just set the timing at stock position with the tuner and do the timing with the timing adjuster. Some people will say timing adjusters are a waste of time when you have a tuner... but I dont think so. Not to mention if you want to add N20 untuned then you can adjust it a little better with the timing adjuster.
Sep 1, 2015 08:16 PM
