screaming noise at 6k rpm
Old 07-28-2013, 07:38 PM
the02stang
the02stang's Avatar
Post screaming noise at 6k rpm
sometimes when im driving my automatic 2000 mustang gt (89k miles) i hear a screaming noise at high rpm until it falls back down. its like an annoying high pitched noise that lasts a second at high rpm. i dont want the car to end up breaking down, this is my first mustang gt and v8 and im not sure what it might be.
It was said to be all stock when i bought it a month ago.
I took it to the dealership and got a visual checkup done , they said that my belt was starting to wear out and my breaks needed to be replaced. everything else was fine.
Also, my exhaust pipe is bent ever since i got it, any ways to fix it? pics on bottom. pic of left and right exhaust. and both.
[IMG]https://mail-attachment.googleusercontent.com/attachment/?ui=2&ik=4adad0fa1f&view=att&th=14027db11537f0fe&a ttid=0.1&disp=inline&safe=1&zw&saduie=AG9B_P_DpJ4V TY6AQZzu4LTW5Jkl&sadet=1375058272171&sads=lqwKYOaC NfaHV0VDQotlW8L5mNk&sadssc=1[/IMG
https://mail-attachment.googleuserco...73nExlQTvyKD_c
THIS IS THE NORMAL ONE...
https://mail-attachment.googleuserco...qWcIhpqXPLq3mg
the02stang is offline
Old 07-28-2013, 07:41 PM
the02stang
the02stang's Avatar
the02stang
the02stang's Avatar
Old 07-28-2013, 07:54 PM
the02stang
the02stang's Avatar
Old 07-28-2013, 08:17 PM
dawson1112
dawson1112's Avatar
Screaming or screeching noise is likely the belt, they tend to screech at high rpm.
It looks like someone hit the tail pipe on the passenger side.
You can probly hammer the dent out of it but to straiten it is going to be tricky . You may be able to move it back over with a long wrecking bar or pipe but you most likely wont be able to get it lifted back up in place.
dawson1112 is offline
Old 07-29-2013, 04:45 PM
RMK01GT
RMK01GT's Avatar
Yes Replace the belt, make sure to check all the pulley's for any play (movement) replace any that are worm out, this will fix the screeching.
The exhaust will be easy to pound the dents out of if you remove it, using a smaller piece of pipe and a hammer put the smaller pipe inside the bent one and use the hammer to work it straight again.
the bend will require you to use a smaller pipe inside to straighten it and use the same strategy to make it round again.
Or if money is no object then you could just replace it...
hope that helps
RMK01GT is offline
Old 07-29-2013, 08:47 PM
bronxbomba63
bronxbomba63's Avatar
It could also be one of your idler pulleys. I had a problem with one making a God awful high pitched sound whenever I started my car or would drive around. Wound up being a bad bearing in the pulley.
bronxbomba63 is offline
Old 07-29-2013, 09:22 PM
dawson1112
dawson1112's Avatar
Another thing to look for when changing the belt if its squealing is burnt rubber in between the ribs of the pullys , squealing belts mean burning rubber and if it gets built up to bad no belt will be quiet.
Old 07-30-2013, 02:21 PM
JJ Glo
JJ Glo's Avatar
My car would squeal at low RPMs, then stop at higher RPMS above 2.5k. I replaced the belt tensioner since it had a bunch of play and one of the idler pulleys, no more noise.
JJ Glo is offline
Old 07-30-2013, 02:48 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Originally Posted by the02stang
Just get an exhaust pipe expander and adjust it until the tailpipe is the rounded back out.
Derf00 is offline
Quick Reply: screaming noise at 6k rpm
