Hurst Shifters
RE: Hurst Shifters
They don't, I went and looked. They do not make a shifter for the TR3650 transmission.
I'd suggest the Steeda Tri-Ax... good shifter. A bunch of others on this forum would suggest the Pro 5.0, whichever you go with, you'll be pleased.
I'm fairly not mechanically inclined, and I was able to do the swap. The instructions Steeda provides are good enough, and the process is fairly simple. Pop off your cover (which holds the boot), unbolt a plate with a boot, unbolt the old shifter, place the new one on, bolt it in place, and re-assemble.
Whichever you decide to get, get it from shiftergaskets.com because he'll send you a shifter gasket with it. Call me lazy, but it was easier just setting the gasket on there instead of getting out the RTV silicone.
Took me about an hour to do, could take others less.
junior04
09-28-2015 10:53 AM
