Head porting
Ok so I have a set of heads from a 2000 mustang that I plan on installing on my car.
Along with the installation I plan on adding a stage 2 comp cam. I need to get a valve job, magnaflux, and a porting job. How much do you think I'll be spending and is there anything else you'd recommend I do?
i know to get mine ported and x-rayed it was like $700 for a valve job figure in another $700 with new valves. i have a set with comp stage 2 cams and comp springs and ported PI heads if you want them
this gonna be a daily? cuz the exhaust vavles are more likely to fail with valve jobs because the heat transfer isnt as good when you grind away some of the material off those exhaust valves
Oh I didn't realize thats what a valve job was. I meant I needed to get them replaced.
I think he is wanting biger valves.
i don't know any thing about them i was just told about this place.
they have the biggest valves i have ever seen in a modular head 220/195
http://www.injectedracing.com/html/Engine_kits.htm
ORIGINAL: sk8erdudex
