Intake Manifold Questions????
Hey there guys I have a vacuum leak behind the manifold it seems like. I can hear the hissing and I also notice a misfire between 1500 to 2000 rpms. So here is what I have done so far I sprayed throttle body cleaner on all my hoses and didn't notice any fluctuating in the rpm. But when I took a hose and stuck one end to my ear and the other to the back of the intake manifold I could really hear it big time. My question is what is back there what hoses, or could it be a broke gasket. My next problem is I pulled two spark plugs out on the drivers side and there was coolant all in the well just in two of them the other two was dry. Would this be a sign of a broken gasket or maybe cracked intake.
Okay I have been trying to figure out how to upload pictures for everyone to see but I cant seem to find the paper clip on here to upload them can someone help me with that so I can get these up
Ya I think you are correct on that one cause I wiped the water out in between my thermostat housing and cylinder 5 and I could see the water building up right under the intake and as well on the back of cylinder 8 I could see water building up. Should I just use a oem gasket or get a after market one? I have noticed my car loves oem parts for some reason. Thanks for the help as well much appreciated
If it's at # 5 carefully inspect the manifold itself where the composite meets the aluminum to be sure that it isn't leaking as this is very common. I have probably replaced more failed manifolds than failed gaskets.
Alright Thanks man appreciate all the help. I also found the problem it was the intake manifold it was cracked between the thermostat housing and in the rear of the intake along with gaskets were cracked.
Okay guy I got everything back on and running now. No more hissing or water leakage so far. But I noticed that once my rpm start to go back down like it will drop from 900 to about 500 or 6ish with a little spitting and seems to run a little rough and it espically does it when I turn the ac or defrost on what else could be causing this something with the ac maybe? Should I of started a new thread for this. Sorry still new here
