2000 GT "chugging" while accelerating
Old Oct 9, 2013 | 11:38 AM
rumtillidie's Avatar
rumtillidie
Exclamation 2000 GT "chugging" while accelerating
Hello everyone
When I'm accelerating I notice the car starts too chug when I have my foot on the gas at a certain position. This usually happens at low RPMS and then when I pull my foot off the gas and press on it again it accelerates properly.
This started happening after I installed a cold air intake and replaced the stock mufflers with two different ones the same day! I tried to put back in the stock intake and noticed I'm missing a piece so I had to put it back together .
If anyone else experienced this problem too if they could let me know what they did! The car has 101,000kms now just hit 100,000 a few weeks ago if that helps.
Old Oct 9, 2013 | 12:05 PM
Stevo86's Avatar
Stevo86
The mufflers shouldn't matter. I suppose you could have done something to the MAF when you took the intake out but it doesn't sound like your problem.
Is it only at a certain point in the throttle? Auto or manual? Does it happen in every gear?
Old Oct 11, 2013 | 08:48 PM
SecludedGT's Avatar
SecludedGT
https://mustangforums.com/forum/4-6l...tter-help.html
Sound like whats going on with yours?
Old Jan 16, 2014 | 08:00 AM
rumtillidie
Sorry for the long delay guys, I forgot I made this thread!!!!
I notice this happens only between 1500 rpms and diminishes and clears up when I go over 2000 rpms. The car is an automatic and only happens when I'm first accelerating, but it continues too "chug" until i go over the 2000 rpms.
I read that thread also SecludedGT, that seems like a different problem but pretty close . I switched out the spark plugs as soon as I bought the car at around 77,000kms.
Old Jan 17, 2014 | 11:16 AM
thatdude305's Avatar
thatdude305
check your ignition coils I had the same problem about a year ago I had a bad coil. they changed the coil and never had a problem since then
GimpyHSHS
19
Dec 19, 2023 01:12 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
Offendant
Sep 23, 2015 07:21 PM
trashxtrash
Sep 20, 2015 10:49 PM
rksnow1
Sep 14, 2015 08:46 PM
