Car Won't Start...TPS?
I'm going to try to word this as clearly and as briefly as possible by making a few key points. Thanks in advance for trying to help with any input.
1) On a clean slate the car starts and idles perfectly. (after resetting the PCM and letting it idle for 15-20 mins so the PCM can re-learn the idle settings)
2) However, if I rev it or drive it (after the initial 15-20 min idle re-learning process of course) the car has a hanging idle. I'll go park the car and shut it off. Then when I try to restart it, it fails to start.
3) I've discovered something really weird. If I simply reset the PCM by disconnecting the battery for the appropriate amount of time, the car will still not start back up.
4) In order to get the car started again, in addition to resetting the PCM, I must completely remove the TPS from the TB, then re-install it while the PCM is being reset. Then and only then will the car start back up and idle just fine. I've tested this theory at least ten times and am ready to call it law.
5) It's great that at least I know what I have to do to get it started and idling perfectly again, but why and what the hell is going on???
Additional relevant information: Aftermarket TB, New Ford TPS (same exact issue with old TPS)
Ugh. I really didn't wanna get to that. Not that it's difficult, but car's only got 50k miles and it was fine before the new TB...What do you think about having to remove the TPS and re-install it?
OR is the butterfly notch supposed to sit where it will have to rotate quite a bit to come into contact with the TPS notches?
I'm doing it the 1st way.
Okay, just checked to be sure if I'm putting it on incorrectly but I can't even make it fit the other way. If I try to, I can't even rotate the TPS enough to fit that way because the iac is in the way.
I dunno. I'm at my wit's end. I'm gonna put the stock TB back and see if this does anything.
It just blows my mind that the TPS has to be removed, then re-installed for the car to start again. This to me meant to change the TPS but that didn't fix it.
I don't think it's the IAC since the problem started after the new TB.
I'm quite sure there are no vacuum leaks.
Again, the car starts and idles perfectly until you depress the accelerator pedal.
If I start the car and it runs perfectly, I can turn it off and on as much as I want with no issues. It's only AFTER the throttle has been opened that the car won't start again after I shut it off.
