Clutch Work
Okay guys, let the fun of buying a used car begin. Havent even made my first payment yet... Pressure plate has gone out. 2004 Roush 440a. TR-3650 tranny. Heres the situation im in. Im Active duty military. E-3, dont get paid the most. What ive done so far...
Exedy Mach 500 Stage 3 Clutch - $360 (Thinking i went a little over board and a stage 2 would of been fine...Going to swap out for the Mach 400 stage 2 clutch... should be more than enough. Its the stock roush 3, supercharged...only difference is exhaust. i doubt im putting down more 500 ft/lbs of torque...will save me about $130 bucks)
Ford Racing TOB - $60
Ford Racing Pilot - $11
Heres my situation.
Ive been quoted $290 for 4 hours of labor and flywheel resurface by a local shop for the clutch install. (Military discount rate)
Would it be better for me to do that, or purchase the
Exedy Lightweight Racing Flywheel - $330, and do the install myself.
We have a DIY shop here on base, i can rent a lift for $5.50 an hour. Ive done clutch installs on mustangs, i know they suck...i know what im in for.... unfortunately my wallet wont allow me to purchase both the flywheel and get someone else to install it... What would you do? Personally id rather do it myself, and know it gets done correctly...
I also have friends that are willing to help, however....are not mechanically inclined to say the least. :P Heck...if any one who reads this is in the Tampa Bay area and willing to help... Id glady reimburse you for your time and help
Having shop install im looking at all said and done, $588...If i do the work, Im getting a brand new flywheel, and all said and done about $650.
Heres my situation.
Heres my situation.
Heres my situation.
To have your flywheel resurfaced is $40 at napa and a skilled guy doing that job in a proper shop will probably do the swap in about 2.5 hrs. Theyre quoting 4 but usually takes half of that.
I just paid for a complete dif and gear swap plus some suspension work and clutch, and cable swap cost me $850 in labor.
Yeah im AD. i mentioned the hobby shop in the post. Im decently mechanically inclined so i have no issue doing the install myself... Clutch jobs are pretty straight forward. Its just a matter of not really wanting to do it myself..but also need to do whats best in the long run. This pressure plate took a dump... As it sits right now, i have ZERO slack in my cable, and its still barely disengaging. i need to do something ASAP before i start frying my synchros. Not to mention how heavy this clutch pedal is...
I am most likely doing it myself...im just stuck between sticking with the stage 3, or dropping down to stage 2...The car is a daily driver. Need it to be as streetable as possible...im putting down 450 fwHP MAX.
So i bit the bullet and did the work myself...Clutch was toasted. Flywheel will need a resurface...however i just went ahead and purchased a new flywheel. I put in the Exedy Lightweight flywheel, along with the Exedy Mach 400 (Stage 2), along with FRPP TOB and PB.... Job wasn't too bad...biggest pain i had was removing my starter...and the long tube headers didnt make life all the easy either... Had to twist the tranny to get it out...
Didn't even know it was possible but who ever previously opened it up, put the TOB in wrong.
Heres some pics of previous clutch / flywheel
Not sure if its the same on a 2000+ stang but the top starter bolt on my 96 was a major PITA to get out! That one bolt took longer than the whole job.
HIS S-197
Aug 10, 2015 05:47 PM
