Timing question
Old Oct 15, 2005 | 12:39 AM
2000STANGGT's Avatar
2000STANGGT
Default Timing question
I have heard that 14 degrees is where you want to set the timming with a timming adjuster. but with the predator where do you set it to equal 14 degrees? I have mine at 5.00 I think.
Old Oct 15, 2005 | 01:26 PM
02StanGT's Avatar
02StanGT
Default RE: Timing question
The predator will not advance the timing as far as the actual timing adjuster. Anyways its in percent on the predator, not degrees. Also, the timing is only adjusted on the predator for Wide Open Throttle (WOT). With a timing adjuster its adjusted all the time.
Old Oct 15, 2005 | 09:35 PM
04BlueGT's Avatar
04BlueGT
Don't forget to adjust the timing using the grade of fuel (octane) you plan on running. If you adjust it with 93 running in it, then you're stuck with that and can't drop down to 87. I'd recommend that you set the timing running 87.
Anyone else have more advice for him?
CarrieS
Sep 1, 2015 01:00 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
stormesixx
Aug 25, 2015 09:11 AM
ding56
Aug 14, 2015 02:40 AM
