Camber Kits?
Old Oct 16, 2005 | 04:34 AM
Jimmz's Avatar
Jimmz
Default Camber Kits?
I recently lowered my car with the eibach pro-kit and KYB shocks and a Struts. I already got an alignment but I didn't get a camber kit. I now have the money to get a camber kit but will I have to get my car re-aligned once I intall the camber kit? Also a friend told me that if you get a camber kit, the car will raise a little bit but Im not sure if this is true does anyone know?
Old Oct 16, 2005 | 05:09 AM
Voodoo's Avatar
Voodoo
Default RE: Camber Kits?
How does your car ride with what you have now? I am installing lowering springs next week and I was wondering if I needed CC plates and I was told no if I only lower it no more than 1.5". Is it aligned fine now? If it is I wouldn't mess with it. and yes you would have to realign it.
Old Oct 16, 2005 | 08:06 AM
04BlueGT's Avatar
04BlueGT
If you had an alignment done, then I'd leave well enough alone. If you install the C&C plates, you'll have to re-align the front.
Voodoo, you should be fine with an alignment. I put two inch drop springs on my car, but the drop was less than 2 inches. Much less. I measured from the top center arc of the wheel well before and after. I dropped about 1 inch rear and maybe 1/2 inch up front. However, I have the DZSports, not Eibachs. I did install offset rack bushings. They lift the steering rack up to help adjust steering geometry. Takes about 10 minutes on a lift. THey come in aluminum or polyurethane. I opted for the aluminum to avoid rotation of the bushings.
Hope this helps.
Old Oct 16, 2005 | 12:31 PM
Jimmz's Avatar
Jimmz
Yeah you dont really NEED cc plates. They just give you longer life on your tires. I'll just leave it alone. I got the eibach pro-kit and since I got aftermarket shocks and struts it lowered it a little more so its about a 1.75 almost 2 inch drop. I was just wondering, I figured I would need an alignment. Oh well guess I dont need a camber kit....
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
