help me
RE: help me
My 01 is lowered 1.5 in. and I dont have problems bottoming out even with my mid-pipe hanging low. Maybe try and just go around the speed bumps if possible or take them slower. Have you done any other suspension work?
RE: help me
Sounds like you're more than 1.5 lower. The stock measurement on my '04 was 28.5 F/28.0 R from ground to center arc of wheel well. Check to see if you are closer to 26 on either one. If not, do you have U clamps on the exhaust and are they pointing down?
If that's not it, then raising the car a little may be your only option. You can buy polyurethane isolators swap out the worn out factory rubber pieces. Pain in the butt, but you should get back 1/4 to 3/8 inch 'lift'. Plus, they are good for life and stiffer than rubber.
I got my Prothane pieces at www.stangsuspension.com and didn't spend a fortune. Good luck.
