HELP! with weight reduction...
Old Oct 17, 2005 | 06:53 PM
DILO2001GT's Avatar
DILO2001GT
I ♥ Acer
Default HELP! with weight reduction...
what can i do to lower the weight of my car. i already have took out to spare tire and back seat. i don't want to remove the electric windows but i wanna get down close to 3000 lbs if i can. should i get some lighter seats? maybe some corbeaus. whats the thing ppl are doing to lighten there car dramatically? i don't wanna drive around with it gutted but if i can figure something out to still make it look good i will. so post away
Old Oct 17, 2005 | 06:55 PM
DIVER8374's Avatar
DIVER8374
Default RE: HELP! with weight reduction...
Did you already get a tubular K member? If not that is a good one.
Old Oct 17, 2005 | 08:42 PM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: DILO2001GT
Getting to 3000 pounds is pretty hard. You are probably looking at taking out at least the A/C, the airbags, and getting some lightwieght racing seats, and doing the K member. And I still don't know if your gonna be looking at 3K. And it would suck not having the A/C and the airbags. (dunno if it will even pass inspection.
Old Oct 17, 2005 | 09:19 PM
DILO2001GT's Avatar
DILO2001GT
I ♥ Acer
inspection won't be a problem
yeah i'll check into those things. my a/c doesn't even work and my air bags don't seem to go off anyways thanks.
Old Oct 17, 2005 | 10:41 PM
04BlueGT's Avatar
04BlueGT
It depends on whether you are dedicating the car to strip use only or not. If so, then there is a lot you can do. If you looking to reduce weight, but still drive it, then an aluminum block would help. Expensive, but light. Tubular control arms with the K member and coil-overs, and an aluminum radiator.
You're limited for the daily driver, but for the track, you can quickly shed weight and $ at a disproportionate rate.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
jar_are_red
Sep 24, 2015 07:03 AM
Sep 8, 2015 11:50 AM
