Instructions for setting your idle according to Ford Racing
Foghorn Leghorn
Location: I reside in a near constant state of amazment.
I got an email from Ford Racing when I called them about some starting issues I was having with the Mark VIII swap and the first thing he asked was, "Have you set your throttle position sensor?"
Me..."Duhrr..no."
Him, "Let me send you an email."
He sent me a PDF file but I don't know how to post it up but here is the procedure for setting the idle according to:
Ford Racing
Idle Setting Procedure
Please Note: These steps MUST be performed in sequence!!
1. Get engine to operating temperature.
2. Disconnect IAC (Idle Air Control) Solenoid. If engine stalls, turn throttle-stop screw in one full turn and restart. Repeat as necessary until engine will idle with IAC unplugged.
3. Set idle using throttle stop. Idle speed will vary depending upon modifications made to the engine. Set to where you are comfortable with idle speed.
4. Set TPS (Throttle Position Sensor) anywhere from .96 to .98 volts. This is done by loosening the mounting screws, and lightly rotating TPS. If you cannot obtain the desired range, you may need to make the mounting holes slightly larger. This can be done by drilling them.
4a. TPS wire colors to be probed are generally BLACK and GREEN wire or the GRAY/RED and GRAY/WHITE, depending on your vehicle.
5. Stop engine. Disconnect negative terminal battery cable for 15-20 minutes. You may wish to tap the brakes or turn the headlights on and off a few times as this will help to ensure that you have purged any remaining electrical current from the vehicle.
6. Reconnect IAC Solenoid
7. Reconnect battery cable to the negative terminal
8. Restart engine.
9. If problem persists, inspect for mass air meter problems and possible vacuum leaks.
/end instructions
It didn't cure my starting issue but it sure did idle much better.
Me..."Duhrr..no."
Ford Racing
8. Restart engine.
/end instructions
squishbang
Suspension
11-02-2015 03:42 PM
