2000 Mustang GT Mileage won't show on gauges
I picked up a 2000 Mustang GT for $300, the car runs and drive, the only issue is I can not get the mileage to show. All other gauges work normal but I can not get the mileage to light up at all. I am not sure where to start looking at, all help would be appreciated.
Yes the odometer, the speedometer and RPM and every other gauge work just will not show miles. I have another Mustang GT I can swap odometers out with to see if that fix the problem.
i can explain it......the cluster contains the PATS (passive anti theft)information and if swapped out for another will result in a no crank anti theft event. the only way to make a swapped module work is to program that module to the car, and then program 2 keys.
If you end up swapping clusters you can have PATS disabled via tune to avoid the expense of having everything reprogrammed.
09-21-2016 12:11 PM
07-13-2016 12:55 PM
justinleggett
07-06-2016 04:03 PM
