bounceing idle and stalling
Old 03-30-2017, 08:53 PM
  #51
tadpole1969
tadpole1969's Avatar
just a little update did finally replace the iac today no surgeing as of yet ! went ahead and put the bbk tb bk on sence it was not the problem, if iac was the problem then wow! autozone needs to drop the companys putting out these sorry replacements for sure! Makes 2 that i got from them that was bad. whats got me is it would idle down when i unplugged it , guess it would stick everynow and then
tadpole1969 is offline
Old 03-31-2017, 02:48 PM
  #52
WJL
WJL's Avatar
Hope that's it the one made by DENSO seems to be the best
WJL is offline
Old 03-31-2017, 06:25 PM
  #53
tadpole1969
yup it is, took her a spin today and think i need to set reset base idle its idleing kinda low and tends to rev up when put it gear then falls to like maybe 300 then recovers and idles around 600 to 650 a tad low for my taste
Old 04-01-2017, 08:30 AM
  #54
Fogeymeister
Fogeymeister's Avatar
FYI: The TPS voltage is also affected by the mounting. If you loosen the mounting screws, there's enough "slop" in the mounting holes that you can adjust the voltage by moving the TPS body then tightening it back down.
Fogeymeister is offline
Old 04-01-2017, 11:21 AM
  #55
tadpole1969
On the 2001 gt? dont think it would even move enough to change any thing
Old 04-03-2017, 02:32 AM
  #56
dawson1112
dawson1112's Avatar
It depends on the tps, if its factory or oem replacement for the new 4.6l engines it wont have any adjustment at all other than resetting the idle screw to factory with a feeler gauge.
But people have been known to use an 1/8th inch drill bit to slot the holes of the tps in order to make an adjustment on it, but really the car should run fine any where from .89-1.0 volts at closed position.
OP make sure when you do a base idle relearn that your turn every thing on high including A/C. This will insure that computer learns idle strategy even under load from the alt, ac compressor. That should get you where you want to be idle wise, 750-850 adding 50 for autos 800-900 rpm is acceptable.
dawson1112 is offline
Old 04-03-2017, 05:37 PM
  #57
WJL
WJL's Avatar
With stage two cams you'er going to need 850 RPM at a minimum, as you already know you can set this with a tuner.
This is not the first time I've heard this story i read one where they took the iac back three times, I think on mustang evo or something like that.
Good to hear you got it solved
WJL is offline
Old 04-03-2017, 11:01 PM
  #58
tadpole1969
yup i have just about got it to the sweet spot for idle ! no more surgeing , idle doesnt rev up then way down like it was when put in gear, what a relief
Old 04-03-2017, 11:11 PM
  #59
tadpole1969
you mean the drive idle option in the sct tuner correct ? i currently have it set to 810 and 720 in Neutral
Old 04-04-2017, 05:01 PM
  #60
WJL
WJL's Avatar
That's it
WJL is offline
