clutch adjustment not working
Old 03-16-2017, 04:31 PM
mike327
mike327's Avatar
Default clutch adjustment not working
using the method of pulling up on the clutch, i get no movement on the pedal. any hints?
mike327 is offline
Old 03-16-2017, 04:58 PM
WJL
WJL's Avatar
What makes you think it needs adjusted?
WJL is offline
Old 03-16-2017, 09:13 PM
dawson1112
dawson1112's Avatar
The only thing pulling up on the pedal will do is let slack out of the cable one tooth at a time on the quadrant. But it will only self adjust if its needed. If your not experiencing slipping or drive-ability issues it probably just isn't ready to self adjust yet.
If you are having problems with slipping or shifting then it is quite possible the clutch is almost done and the adjustment has reached the maximum slack on the cable.
dawson1112 is offline
Old 03-17-2017, 09:26 AM
mike327
mike327's Avatar
thanks...i've had the car 2.5 years...the clutch engages like a switch, right off the floor...it pulls like a train, no slip...sometimes, when hustling, the gears do grind a bit when shifting. i just want more clutch travel for smoothness
mike327 is offline
Old 03-17-2017, 09:58 AM
dawson1112
dawson1112's Avatar
If you want the clutch to disengage farther from the floor, you need to take up some of the slack in the cable. You will need to lay on the floor and look up at the quadrant,, press the pedal to the floor and using a large screw driver hold the quadrant in place and lift the pedal slowly from the floor. It will click ,, you only want to do about 1-2 clicks and that will make the cable shorter so the clutch disengages sooner.
