What might this leak be?
Welcome!
Kinda looks like oil, from here. You need to get a better look at it though. Check your fluid levels and try to locate the source of the leak. That chassis looks pretty clean underneath, so it shouldn't be too hard to find.
Could be. Get some on a clean piece of paper to confirm color.
If this is an automatic, then there should be a drain plug on the torque converter that you can check for leakage. Otherwise, any leaks in the bell-housing area will require pulling the transmission out of the car to fix.
