Need help with tick/tap issue 2v
Old 11-12-2018, 12:50 PM
Jacob Stewart
Jacob Stewart's Avatar
Default Need help with tick/tap issue 2v
To break it down into simple terms:
i have a mustang, that originally was a v6. I swapped the motor to a 97 4.6 2v that i did a complete overhaul on, as well as comp 270ah cams and trick flow lash adjusters. Swapped the trans to a T45, and rear axle to an 8.8, and swapped every hsrness in the car. Recently, I decided to do a PI swap. Bought a set of heads, had them cleaned, resurfaced, valve job, and the thew them on accompanied by arp head studs, new chains, new chain guides, and new tensioners. I got the car running, and when it first fired up, it ran great. Its also worth nothing i threw 30lb injectors in, even tho the car isn’t tuned for them. Even with the 30lb er’s, the car ran smooth. No belt accessories were hooked up, we simply hooked fuel and ignition up and fired it. NOW, we put the car all the way together and it makes a tick/tapping sound, and will stall out if you try to drive it. Originally I thought it may just be a lash adjuster or cam follower, but i have no idea now. Also, car back fires when its cold, have to hold it at ~2k for a sec for it to idle. ANY INFO HELPS. Here is a video of it running:
Jacob Stewart is offline
Old 11-12-2018, 04:48 PM
pure_kaos
pure_kaos's Avatar
My 02 kinda sounded like that before it blew a spark plug out of the well.
pure_kaos is offline
Old 11-12-2018, 08:46 PM
Jacob Stewart
Thank you for reply, i’m going to look at the plugs and pull them out and inspect them. Maybe ill find something.. im also going to pull the pass. Valve cover and turn it over and watch for oil. I am suspecting and oiling issue maybe? The first time i pulled cover it looked dry
Jacob Stewart
11-12-2018 11:32 AM
madmav3024
08-12-2017 07:43 AM
FLMustangMan
05-15-2011 05:57 PM
klove651
07-20-2009 12:47 PM
aMerICAn_mUsCLe79
12-20-2007 02:17 PM
Quick Reply: Need help with tick/tap issue 2v
