98 GT w/ the following....
Old 11-01-2005, 03:03 PM
TheBob98GT
TheBob98GT's Avatar
Default 98 GT w/ the following....
hey guys. with my currents mods and ported Pi heads, vt stage 1 cams, Pi intake manifold, nitrous, and shorties what (estimated) would my car put out in horsepower and torque and about what would it run in the 1/4? just can it get me in the 12's?
TheBob98GT is offline
Old 11-01-2005, 03:10 PM
blacllkllsi
blacllkllsi's Avatar
Default RE: 98 GT w/ the following....
what shot are you running??
blacllkllsi is offline
Old 11-01-2005, 03:34 PM
TheBob98GT
TheBob98GT's Avatar
nothin above 100 shot. prolly will use 50 for a while then go higher
Old 11-01-2005, 03:51 PM
blacllkllsi
i dont think you will be able to touch 12's with the 50 shot. Possibly mid 13's With the 100 shot however high 12's are doable
Old 11-01-2005, 09:32 PM
TheBob98GT
TheBob98GT's Avatar
does anyone else have experience with a similar setup like this?
Old 11-02-2005, 08:53 AM
DIVER8374
DIVER8374's Avatar
With just the PI swap and the VT stage 1 cams (and a really good tune), with all you other mods (if you can hook up at the track) you should be able to run a 13.1-5, with the Nitrous you should be able to break into the 12's. The 4.10's are going to help a lot you will just need to get all the power to the gound!!
DIVER8374 is offline
Old 11-02-2005, 01:29 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Full PI swap with cams + your current mods, you should be able to get into the low 13's, easily into the 12's with some juice. If you can drive, otherwise you might run 14's still!
Dan04COBRA is offline
Old 11-02-2005, 01:48 PM
Emann0007
Emann0007's Avatar
I don't see why he couldn't hit low 13's with just the PI swap VT cams and 4.10's should be under 13.5 assuming you have traction. A 75 shot is perfectly safe and will get you into the 12's from there....
Emann0007 is offline
Old 11-02-2005, 01:57 PM
ibeeskeef
ibeeskeef's Avatar
A thought for all of you posters that constantly ask what your car would run with the mods you have. GO RUN YOUR CAR!!! After you run it you will have the answers you want and you can report back to us telling us what you ran, not asking what you will run.
ibeeskeef is offline
Old 11-02-2005, 02:13 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
ORIGINAL: ibeeskeef
Um, relax? I think for someone with less than 30 posts you should be a little nicer.
If you have a problem with it, simply don't read these threads.
Quick Reply: 98 GT w/ the following....
