Engine (?) is stuttering
Old Jul 21, 2020 | 12:10 PM
ScraTTrZ's Avatar
ScraTTrZ
Default Engine (?) is stuttering
Good evening (Switzerland time...) together
First, I am very sorry about my bad English, I am sorry for that. Please ask me if you didn't understand anything...
I got a 2007 GT (imported) since 3 years, 84k miles, car services has been done according to the service manual (yes, everytime). I never had problems with the car since now.
When I drive the car with cold engine I have absolutly no problems. But when the engine is warm I got a ratteling sound from the engine (?) or from the exhaust when I am at lower speeds an hit the gas pedal shortly. I can't comprehend where the sounds comes from.
Description:
- When the engine is warm and I hit the gas pedal shortly in low rotational speed (like < 60km/h == 37miles / h)
- On the highway or streets with more than 37 m/h I have no problems
- Engine stutters when I have to stop at a red light or when I want to park
- When the engine stutters and the car has been turned off I can restart it without problems or anoying sounds
On my list to check is
- Fuel pump
- Oil pump
- Coil Packs
- Vacuum leak
Any more ideas?
Best regards,
Marco from Switzerland
Old Jul 22, 2020 | 08:57 AM
Benni614's Avatar
Benni614
Hey and wow Switzerland thats amazing I was deployed there such an amazing experience.
OK. The easiest thing is to go back over the things that typically c a use this issue.
Check and clean the mad but be careful with this, of the wire is broke u need a new one.
check the tps sensor?
check the iac ?
send or post a video when you can of the issue
Old Jul 22, 2020 | 09:21 AM
delling3's Avatar
delling3
If you have a 2007 Mustang GT, your car has a 3-valve Modular V-8. This section of the forum is specific to the 1996 - 2004 years, which have either a 2-valve motor, or in some cases a 4-valve motor. Not saying you won't get good advice here, but you may get more specific information if you post here: https://mustangforums.com/forum/2005-2014-mustangs-43/
Good Luck with your issue.
kalli
May 15, 2010 04:32 PM
SUPER SONIC
May 2, 2010 01:59 PM
bjm3.8
Sep 23, 2009 07:47 AM
MustangGTroy
Nov 25, 2006 03:48 PM
5.0coupe
Oct 3, 2005 08:54 PM
