first mods on a 99-01gt
I am aboutto purhcase a 99-01 gt and im not familiar with the engine yet so i dont know how to modify it correctly. I think i want to change my gear ratio first because from what i read it sounds like a good idea. i heard 3.73s are the best choice and i also heard that changing ur axles would save u a lot of trouble in the future. what do tehy mean changing ur axles?... changing them to what?.. and i plan on puttin 19 in cobra rims on my car in the future so would that affect my gear ratio mod at all? thanks
When you change the axles, you are getting stronger parts for the axle so they won't fail. Getting 19" rims will slow down your accleration a tadbit beacuse the rims are bigger.
<blockquote>Quote: Originally posted by 03 DSG GT on 05 May 2003<hr>
3.73's are a great gear but 99+ 4.10's is really the way to go if you love performance.
<hr></blockquote>
That's correct. Also, if you're a drag racer, 4.10s on an NA car allow you to cross the 1/4 mi. traps at or near redline in 4th.
19-inch wheels will not slow acceleration if the tires are of appropriately lower sidewall ratio. Big wheels with low-profile tires usually yield less traction, though, due to less elastic rebound.
<hr></blockquote>
I HAD 4'10'S BUT WHEN I PUT THE JUG ON MY CAR I SPUN ALL THE THROUGH THIRD ON SREET TIRES AND ON DRAG RADIALS SO I PUT THE 3'73S IN THERE AND I LIKE THOSE ALOT BETTER AS FAR AS THE AXLES THERE FINE UNLESS YOU RUN SLICKS I DIDNT HAVE A PROBLEM UNTIL PUT A SET OF SLICKS ON IT MY AXLES WERE TWISTED AS A DRILL BIT. LOL HOPE I COULD HELP
