Power steering pump leaking
Hello I have a 01 gt and the pump seems to be leaking a ton of fluid, I replaced the nylon washer in the hi-pressure line cuz mine was split into two and it didn’t end up fixing my issue. I saw the fluid leaking out of one of the bolts that go into the block. With closer inspection it does seem to be psf instead of engine oil, but I could be wrong. When I open the reservoir it pops open like it had a ton of pressure and the fluid I add is almost foamy. Any help would be useful. Thank you
