backfires
Old Nov 17, 2005 | 08:24 PM
troys98gt's Avatar
troys98gt
Default backfires
i have a 98 gt 4.6 it wont run, when i try to start it it backfires and blows the air hose off the map sensor, i first found out that if i took the passenger side coil pack off it would run on 4 cylinders without backfire, once reattached it would backfire. so i changed the coil pack and got the same result, i then tried a new crank sensor and still got backfire. im gonna try the harmonic balance (crank damper) to see if it has shifted. im at a loss right now and dont know what else to check, if anyone has any input on this subject or have heard of such a problem i would greatly appreciate it .
thank you,
troy
Old Nov 18, 2005 | 03:00 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: backfires
Scratch what I just said... I was thinking of something else. If I were you, I would check your timing also. On an engine with many miles, the timing chain has a tendency to stretch. Just a thought.
Sean
Aug 15, 2004 03:50 PM
Disgustang
Jul 27, 2004 09:43 AM
Obsol3te
Jul 26, 2004 08:42 PM
spuckie
Nov 21, 2003 05:51 PM
tchamber
Nov 9, 2003 05:47 AM
