power difference mach 1 vs gt
RE: power difference mach 1 vs gt
I had a 2001 GT, albeit automatic, and currently have a 2003 Mach 1. The difference in performance is very noticeable and made eating the depreciation on the GT much easier to take. The HP difference is largely due to the higher compression ratio of the DOHC engine and improved cylinder heads. Other than the suspension and brakes, many of the other performance components are similar or identical to the GT.
http://mach1registry.com/Specs/Specs.htm
heres a side by side comparison of a gt and a mach
ORIGINAL: wwmost
ive seen some peaople make their sohc gt engins into mach engins by putting on the heads or somthing. what is need and is there a kti?
Anyway, the Mach is a totally different beast than the GT.....For starters, the mach has the 4 cam/4 valve per cylinder setup, twin throttle bodies, a cool shaker hood, upgraded suspension components and bigger, better brakes.
It is more like a 99 or 01 Cobra with a solid rear axle than it is like an 03 or 04 GT.
45 more HP than the GT too
cardsrus1
19
09-15-2015 08:37 AM
