PO153 OBD2 Code
Old Dec 13, 2005 | 02:52 PM
n/a_threat's Avatar
n/a_threat
Default PO153 OBD2 Code
Ever since I started putting aftermarket exhaust on my car, I've been running into this problem. I had it when I had manifolds, and my old bassani catted x-pipe and mac catted h-pipe, and now with my headers and x-pipe. I know it is the passenger side upstream 02 sensor that is reading slow. I've had Ford replace that sensor twice and it still comes on. I'm running MIL's on the back o2's. My last alternative is to change both front o2 sensors with some quality/performance aftermarket o2's.
Does anyone have this problem? Do any of you guys drive around with the Check Engine Light going, knowing that this is the code and just don't worry about it?
I'm wondering if I'm doing any damage to my cats or the engine it self (maybe running lean or rich). But I guess if that where the case I'd be getting that code too.
The only advice I've gotten from the dealership is to put the stock system back on, but who wants to do that?
Old Dec 13, 2005 | 02:56 PM
xx9gt6xx's Avatar
xx9gt6xx
Default RE: PO153 OBD2 Code
The 02 sensor code will run your car rich. That's why you need the MIL's. But if your still getting the code then you really should replace your 02's. Long term it'll make your car run like poop...[:'(] Good luck with whatever you do though...
Old Dec 13, 2005 | 03:42 PM
n/a_threat's Avatar
n/a_threat
I have MIL's on the back two sensors. Has this happened/is happening to anyone? Do I need to buy two new upstream sensors? If so, what brand? Denso, NTK, Bosch. . .?
Old Dec 13, 2005 | 04:57 PM
Matts00GT's Avatar
Matts00GT
You have long tube headers with 02 extensions? All the wiring is long enough? If you just spliced into it then I recommend buying the extensions. They are MUCH better.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
mustangheaven
Sep 29, 2015 11:00 AM
