HELP ME NOW!!!!
HELP ME NOW!!!!
how do I get the nut off of the top of the strut guys....? Theres a small groove in the bolt, but I have broken everything tryng to hold the bolt stil by inserting things into the slot s I attempt to loosen the nut. WTF do I do?
RE: HELP ME NOW!!!!
well you put a screw driver in the slot on the strut and then use a wrench to turn the nut loose but it sounds like you are having problems with that. i have had to cut throguth the nut and top of the srut with a cut off wheel befor when that happend.
RE: HELP ME NOW!!!!
ORIGINAL: Emann0007
I would strongly suggest getting an air compressor and impact gun for both removal and installation.
RE: HELP ME NOW!!!!
ORIGINAL: Emann0007
I'll go buy a compressor and an impact gun because I obviously have the money and means to use it... NO! I'm poor and live in apartment with no garage.....
When it comes time to put the new nuts on the new struts though..again, you may only get so far before they just start spinning the whole strut rod. You can get around this though by using a regular nut and a lock washer vs the lock nut that comes with the new strut.
RE: HELP ME NOW!!!!
Were talking about the main nut on top of the dampener bushing that holds it all together right? Sorry for the lack of technical termenology.
I actaully removed struts and took out the shooks today(how wierd?) Im with derf, the job is a real bitch without an impact gun (or at least id imagine so, I had the luxury) Your probably better off looking for a guy on MF.com in your area with one or finding a friend with one whod help you, instead of continuing this way.
Sorry I couldnt provide any technical information, just makin a suggestion for ya
Jim
Jim
RE: HELP ME NOW!!!!
ORIGINAL: kartracer55
Jim
Jim
Yep also called a strut bearing plate, strut plate, or just dampner plate. All the other bolts are easy..just the center one is a biatch.
RE: HELP ME NOW!!!!
ORIGINAL: Derf00
Jim
Jim
Thanks for the info!
Jim
RE: HELP ME NOW!!!!
ORIGINAL: Derf00
Struts are much easier with an impact wrench (gun style). If you're using hand tools you may have to cut through the nut as Tim mentioned. Keep in mind, if you're having problems removing the nut, you may have just as hard of time putting the new nut on the new strut as they are typically locking nuts.
ORIGINAL: Emann0007
