Sytem Too Lean Code
Old Jan 12, 2004 | 02:54 AM
mabguru's Avatar
mabguru
Default Sytem Too Lean Code
I love my OBD II Scanner I got. Anyways the codes its reading are P0171 "system too lean bank 1" and P0174 "system too lean bank 2." YOu guys got any info or solutions for this? I'm running cheapy gas, could that be it? <edited><editID>mabguru</editID><editDate>37998.0376967593</editDate></edited>
Old Jan 12, 2004 | 02:56 AM
Dan04COBRA's Avatar
Dan04COBRA
You can try better gas, but superchips suck and I suspect that being your problem, your intake & exhaust is fairly modified for that hunk of crap.
Old Jan 12, 2004 | 05:27 PM
N2OJunkie's Avatar
N2OJunkie
I ♥ Acer
Originally Posted by Dan02GT
You can try better gas, but superchips suck and I suspect that being your problem, your intake &amp; exhaust is fairly modified for that hunk of crap.
</P>
I agree with Dan, how come you installed a Superchip without any sig mods to your motor...that does n't make sense to me..waste of money and resources (for now), unless you are thinking of doing more heavy mods later. If your banks are really Lean, let me tell you, lean conditions are not good, it can kill your engine.</P>
Old Jan 12, 2004 | 05:38 PM
mabguru's Avatar
mabguru
I'll tell you a few reasons I got the chip. It takes off your governor and rpm limiter. It also changes fuel curves and ads hp. I could tell when I got it, and I got it about 2 years ago. I also have PI heads, cams, and lower intake sitting in my shed. I'm sending them off to get ported and polished in the next week or so. Then a few weeks later getting them installed. So I got some mods in the bag, but back to the question of being lean. What could I do to fix this, better gas?, bigger injectors (if so what size), new chip? What! What! What! Or what can I look for in the future after the P.I. mods?
Old Jan 12, 2004 | 05:44 PM
N2OJunkie's Avatar
N2OJunkie
I ♥ Acer
</P>
I'll call the place where you bought the chip to have it recalibrated or reprogrammed. Too much air is getting in through the intake, not enough fuel..bigger injectors will be te next thing?, fuel pump?....or make is a fake out because the chip is not well programmed, just make sure that your engine doesnt blow off, thats the main concern. Also trying erasing those codes to see if they come back, if they do then something real is happening.</P>
Old Jan 12, 2004 | 05:46 PM
vfast's Avatar
vfast
I ♥ Acer
well I would pull the chip...til you do..you don't need todrive 150 mph anyway and ******* a stock engine for what if $$$ is not involved you wasting it..with all those mods the chip will be useless and you'll need a pms/tweecer or a f.a.s.t. system..
N2OJunkie's Avatar
N2OJunkie
I ♥ Acer
what exactly does this means:</P>
</P>
quote: .........."It also changes <FONT color=red size=4><U>fuel curves</U></FONT> and ads hp", are you noting a huge chnge in fuel economy?..to the good side I mean..this may explains the lean condition.</P>
Old Jan 12, 2004 | 06:01 PM
mabguru's Avatar
mabguru
Here this is a quote from superchip. </P>
<FONT face=Arial color=black size=2>This easy to install plug-in module improves the overall performance of your car, truck or SUV. All modules improve the ignition and fuel curves throughout the entire RPM range for both part throttle and wide open throttle positions which will give you maximum performance at all times. The module dramatically improves the factory Ford electronic transmission by giving a firmer, more responsive shift pattern and raises the shift point RPM slightly. In most cases, this module also eliminates the top speed limiter.</FONT> </P>
Yeah the chip is kinda old, I guess I need to dump it for a good one. I've heard a lot about this tweecer. Whats some good chips and what should I look for? I guess one I can change settings would be the best.</P>
Old Jan 12, 2004 | 06:24 PM
Dan04COBRA's Avatar
Dan04COBRA
You need to dump the chip, unless you buy a chip that was specifically burned for certain mods in mind I would never spend my money on one.
Old Jan 12, 2004 | 11:21 PM
N2OJunkie's Avatar
N2OJunkie
I ♥ Acer
</P>
</P>
</P>
<FONT color=red><FONT face=Arial size=2>'This easy to install plug-in module improves the overall performance of your car, truck or SUV. All modules improve the ignition and fuel curves throughout the entire RPM range for both part throttle and wide open throttle positions which will give you maximum performance at all times. The module dramatically improves the factory Ford electronic transmission by giving a firmer, more responsive shift pattern and raises the shift point RPM slightly. In most cases, this module also eliminates the top speed limiter.</FONT> "</FONT></P>
<FONT color=#ff0000></FONT><FONT color=black>What a bunch of useless meaningless crap..sorry man....</FONT></P>
<FONT color=#ff0000></FONT></P>
