is there anyway to be able to shift with my automatic transmission?
Old 12-18-2005, 04:29 PM
XxphantomsnypzxX
XxphantomsnypzxX's Avatar
Default is there anyway to be able to shift with my automatic transmission?
is there any way to shift with an automatic transmission cuz I might wanna do trackwork in the future but I also would be drag racing
XxphantomsnypzxX is offline
Old 12-18-2005, 05:30 PM
97stanger
97stanger's Avatar
Default RE: is there anyway to be able to shift with my automatic transmission?
i think if you get a transgo shift kit, there is an option where you can shift manually, not 100% positive though....sorry, anybody else please chime in
97stanger is offline
Old 12-18-2005, 05:45 PM
sandcracker21
sandcracker21's Avatar
of cource u can shift with an auto,
u see those numbers?
1 for 1st gear
2 for 2nd gear
D for 3rd gear
UD for 4th gear
unless you have a shift kit tho, constant manual shifting is a bad idea
sandcracker21 is offline
Old 12-18-2005, 05:48 PM
XxphantomsnypzxX
yea but I heard that when u do with the whole shifting the whole way with 1 2 and 3 it does damage to your transmission and will also not always strictly follow it, it will sometimes kick it outta that gear
Old 12-18-2005, 06:08 PM
pj1010
pj1010's Avatar
Just leave it in D and go. Don't break your parents mustang.
pj1010 is offline
Old 12-18-2005, 06:09 PM
XxphantomsnypzxX
lol its mine
Old 12-18-2005, 06:21 PM
GrayGhost01GT
GrayGhost01GT's Avatar
Lol I like that about the parents lol cuz i remember when I use to love to do that kind of stuff in my Parents stang and show off! LOL I dont kno I think it might hurt the tranny because I did do that in my parents stang and had it up to like 60 MPH in 2nd lol Yikes ! Forgot to shirt how stupid! I guess like everyone elese said Transgo Shirt kit?
GrayGhost01GT is offline
Old 12-18-2005, 06:45 PM
Voodoo
Voodoo's Avatar
Yes you can shift it and it wont hurt a thing. You can use it to engine brake in any gear also. They make ratchet shifters that you can use to make positive shifts also. This info comes from Fords Manual.
4R70W
Park
In the PARK position:
there is no powerflow through the transmission.
the parking pawl locks the output shaft to the case.
the engine can be started.
the ignition key can be removed.
Reverse
In the REVERSE position:
the vehicle can be operated in a rearward direction, at a reduced gear ratio.
engine braking will occur.
Neutral
In the NEUTRAL position:
the output shaft is not held and is free to turn.
Overdrive
Overdrive is the normal position for most forward driving.
The OVERDRIVE position provides:
Automatic shifts.
Apply and release of the torque converter clutch.
Maximum fuel economy during normal operation.
Second Position
This position provides:
Second gear start and hold.
The torque converter clutch can apply and release.
Improved traction and engine braking on slippery roads.
Engine braking for descending steep grades.
First Position
If this position is selected at normal road speeds, the transmission will shift into second gear, then into first when the vehicle reaches a speed below approximately 45 km/h (28 mph).
First gear operation only.
Voodoo is offline
Old 03-19-2007, 03:17 AM
/\CHRIS/\
/\CHRIS/\'s Avatar
So it dont hurt a thing to manually shift an automatic?
/\CHRIS/\ is offline
Old 03-19-2007, 03:32 AM
badboystangGT
badboystangGT's Avatar
i used to do that in my old 5.0 and went through 3 trannys i dont know how the new ones hold up to that kinda of abuse, oh and if you do alot of neutral drops that is a forsure way to mess up the tranny!
badboystangGT is offline
Quick Reply: is there anyway to be able to shift with my automatic transmission?
