just took some pics of my ride!!!
#21
RE: just took some pics of my ride!!!
ORIGINAL: stangman2354
Nice ride man... how much did it cost to get the blower installed?
i did the blower install myself, the only couple things i did not do was the clutch and the headers. that is because i just didnt feel like doing them and the guy did both of them for 275 bucks... not a bad deal, huh? and that was at separate times too. the headers were put in for 150 and the clutch was put in for 125 and he had to pull a header to do it.
blower took me around 4-5 hours to install after i did stuff like tapping the oil pan and getting the wiring done. wasnt to hard of job at all... and it was fun starting that thing up for the first time.
#22
ORIGINAL: GT35thconvertable
hey man ive heard alot of people saying I couldnt go over 400 horses out of my gt and I see you have 440.. so how many pounds of boost are you running and who tuned your car or better yet what chip did you use and did you do it yourself..I got the procharged intercooled s/c plan on running 12 lbs of boost.. wanting the same #s.. what are your mods...thanks bro just a stang owner wantin in the high 400 hp range thanks for the help
heres my mod list....
Vortech S-trim SQ-V2 with 10lb pulley
Aftercooler for the vortech w/ IAT located after the aftercooler
4 inch homemade boost pipe
90mm lightning maf
42lb ford injectors
310lph fuel pump
FFRP 3.73 gears
BBK LT headers
BBK catted X pipe
Borla catback
SPEC stage 2 clutch
steeda upper and lower control arms
full length sub frame connectors
steeda caster camber plates
eibach pro springs
blu thunder short throw shifter
75mm Accufab Throttle body
C&L upper intake plenum
all synthetic oils throughout drivetrain/engine
water wetter in radiator (helps motor run cooler)
10% antifreeze/90% distilled water in aftercooler
battery relocated to trunk
then just a chin spoiler, roll bar, and other stuff the last owner did to the car. ive put $0 into looks for this car, but about 6k into the motor.
i use to have black out window tint stuff on my taillights but i didnt like it... i want to find whole assemblies that are blacked out before i do that again.
dan04cobra, the rims have a polished look to them.. but they are dirty in the pictures so you cant really tell.
#26
Nice car. The gauges look good too. Do you like the gauges???? The two that are on the side, how easy are they to see when you are racing? Are they blocked at all by the steering wheel???
#27
ORIGINAL: Zoie_daGT
stangman2354, i havent ran it in the 1/4 mile yet. ive had the blower on there for alittle over a month so far.
#29
#30
ORIGINAL: racer02GTstang
the gauges are blocked when im on turns and stuff but when going straight you can see them perfectly. i do like the gauges, they use to look good when they would light up at night. haha.
ORIGINAL: Zoie_daGT
